ddpsnake
remember gents, every engine wants what it wants,no matter what, i do not pay attention to stock specs, sure its a good starting point, but.
I agree, for the most part the stock Holley is close. It appears the OP should start there. It sure needs more shooter than a 21. Didn't know they made that small. Smallest I've seen is 25. Working the shooter size & cams will cure the flat spot. Jet tuning may be worth a little something too.
Don't worry about having a passenger. That should not be part of your tuning process .
You have already realized that the bigger squirter is helping which was a no brainer like most people have said . At least that's in the right direction . But I think it's safe to say that your main jets are to big as well. On the primary at least.
But instead of jumping all overy the place start right back at the basics .
If your ignition timing is where you want it. Hook up a vaccum gauge to the bottom port at the front of the carb (manifold vaccum ) . adjust your idle mixture screws to get your highest vaccum. Next check your accel pump adjustment , make sure there is 0 play but no pre load. At the slightest touch it should activate your pump (squirter ). Take the car for a drive , nice easy accel from a stop, cruising , do some moderate accel off cruise ( fron 30 mph to 60 maybe ?) as well as from a dead stop. This will help diagnose the first 3 circuits of the carb (idle, cruise and accel/power)
Carb works on different circuits depending on the throttle input when they all work together you will swear it's fuel injected ?
walk before you run !
should I go up to a higher # power valve on the primary like a 8.5 or 9.5 due to my high vacuum reading?
what about smaller secondary main jets and adding a power valve instead of the factory plug?
