Mason
Driving to the gas station now, haha.Ha Ha.....
Too funny moparedtn....
Mason, go buy a lottery ticket!
The wire from the post post of the coil goes to ballast resistor, voltage regulator, and a maybe a few others. It might of melted your switch and/or bulk head too. Youl have to inspect. Also ohm out the coilFor the guys who want to roast, go ahead but I just turned 20 and these cars are fossils to me lol. I know I am not the best with wiring either.
If anyone could give genuine help, I''d appreciate it. The semi pink wire running to the coil is fried and that seems to be it. If I'm not mistaken, is that connected to the ballast resistor?
No, I believe he hooked pos to pos on the coil, and neg to neg on the coilIf you put positive on the negative to the coil then poof? The switched positive hits the positive of the coil the negative is the ground side of the coil from the points or electronic distributor.
Oh dang, you mean he wasn't kidding about hooking both sides of the coil to the battery?
Good Lord....
Is anyone close by to this young fellow, so that we might avert future apocolypses perhaps?
I'll go and mess with it tonight on the voltmeter and see what the coil reads. The problem I initially put positive wire on the coil and no wire on neg post of battery it was no spark, just like when I did connect both.The wire from the post post of the coil goes to ballast resistor, voltage regulator, and a maybe a few others. It might of melted your switch and/or bulk head too. Youl have to inspect. Also ohm out the coil
I know for sure I put the pos with pos and neg with neg. LOL I'm not that terrible.If you put positive on the negative to the coil then poof? The switched positive hits the positive of the coil the negative is the ground side of the coil from the points or electronic distributor.
I completely rebuilt the car without making a mistake this bad lol.Oh dang, you mean he wasn't kidding about hooking both sides of the coil to the battery?
Good Lord....
Thank you for the diagram! Everything seems to be okay in the harness and wires hooked up to the coil terminals. The only one that is toast is a small gauge pink wire (or was pink) before it toasted black.Here’s you a wiring diagram to use for the ignition circuitView attachment 1261299
And a wiring diagram, along with a fire extinguisher.get yourself a test light and/or a cheap little voltmeter
Outstanding!I completely rebuilt the car without making a mistake this bad lol.
