Gotta go to work now...the power's not on yet, so should be safe.
The set frequency of supply at 50 Hz...
Well, that's not in the cards I'm afraid - but that aside, yeah....I'm a lot more cautious than I used to be.GEEZUZ Ed, you ever think of just dying of old age?
Yep, totally agree there...That feeling you get when receiving a 230 Volt shock is one that stays with you for a while. I have had a few over the years....all by someone else's misadventure, and me failing to test thoroughly
The set frequency of supply at 50 Hz doesn't seem to match the sensation of being shaken by what feels like a ***** Grizzly Bear grappling the last bit of food from your hand.
I have to admit - for once the Americans have the better system.Ah, it all makes sense now as to why you don't understand me sometimes. We're on different frequencies
One shock I got was when I was standing on a steel Engineering bench holding two neutral conductors -- one in each hand ready to connect. Everything else was connected (mistake #1) ....and my 'supervisor' was standing on the ground yapping to one of the Fitters.... (mistake #2).Yep, totally agree there...
Only thing I can compare it to was the defibrillator first time I croaked, which actually hit harder.
Holy crap!One shock I got was when I was standing on a steel Engineering bench holding two neutral conductors -- one in each hand ready to connect. Everything else was connected (mistake #1) ....and my 'supervisor' was standing on the ground yapping to one of the Fitters.... (mistake #2).
He turns the switch on and with a 2kW load for heaters, I became the return path for said load.
The story goes that I was bouncing up & down quite a bit before I managed to let go.
Exactly.....everyone laughed.....except the one guy.Holy crap!
One shock I got was when I was standing on a steel Engineering bench holding two neutral conductors...
It's no surprise why this Up/Down light didn't work. Obviously the moron who connected it didn't bother testing afterwards.
For those who are not sure what's wrong......both legs of each lamp are twisted together. It will never go.
