- 4:19 AM
- Dec 4, 2009
- Pasadena, Texas
Like the title says.....when there's no antifreeze in the rad?
That's number 1 how long to freeze it.31...
Sitting inside or outside ?Like the title says.....when there's no antifreeze in the rad?
Well, have one better than that under the oil pan....I stink. Heat light but didn't want to use it if the low for the night is only going to be 29. Might turn it on for a few hours before going to bed.....A drop light with a 60 Watt incandescent bulb will keep it warm enough.
Outside but up against the shop door on the south side.Sitting inside or outside ?
I would dump the radiator, toss a tarp over the engine bay and like delta said use a light or if you have a small electric heater if it's just for 1 or 2 nights. Your betting the weather man is right ?Outside but up against the shop door on the south side.
You're in Texas. Shovel a fresh pile of manure under the oil pan. That will keep the engine warm.Well, have one better than that under the oil pan....I stink. Heat light but didn't want to use it if the low for the night is only going to be 29. Might turn it on for a few hours before going to bed.....
I have some antifreeze but was saving it for my 'better' junk instead of my 'junk' junk! But I'm still having some fun with my junk junk....especially with the straight pipe on this old V6About $35.00 worth of antifreeze will keep you good down to -35 when mixed 50/50 with water. Cheap insurance. These old blocks are getting harder to find all the time.
Having fun with your junk ? Whaaaat ?I have some antifreeze but was saving it for my 'better' junk instead of my 'junk' junk! But I'm still having some fun with my junk junk....especially with the straight pipe on this old V6
