- 6:33 AM
- Jan 16, 2011
- NorCal Sierras
PLEASE Don't take what I'm about to say as an insult,
it's not meant to be...
BUT;
There's a lot more to going fast & running 9's or 10's or 11's even
especially out of some mag. articles, we live in the real world...
Far more than just the heads & a thrown together combo,
mixed match parts, because some part didn't clear the hood
or the idle was too choppy, just throwing parts at it,
not intended to use with each other...
it's the car, driver, trans/clutch/converter, the suspension & travel,
gearing, rotating mass, over all weight & wear the weight is, the shocks, tires/traction,
even the tire pressure or style of tires & compounds etc.detailed carb & ignition tuning,
what fuel, what altitude & weather conditions, what track prep etc.
It's the whole kitten caboodle...
Just one part doesn't make that big of a change, unless it fits all the rest...
1hp per/ci is harder than you think, there's a lot of BS #'s out there too,
especially if the parts aren't right for the specific combo...
There's a ton of people "allegedly" making 500+ hp
that can't run 12's, let alone 13's
IMO it's either BS {wrong}
or "the car's" not set up right for the engine combo...
It could be in the low 11's all things considered,
right weight "all the factors mentioned above" etc., if it really made that power...
I'd suggest getting some books on the subject & study them thoroughly...
Even the old Chassis 9th edition book from MP, it spells it out, old school,
it may be old stuff but the formula still works...
It's been done before you don't need to re-event the wheel...
A lot more to making a drag combo work together, than just the engine or
some "what if" mag combos...
BUT;
