Paul_G
- 3:40 PM
- Dec 24, 2013
- Surprise, Arizona
To the OP I hope your problems are resolved already. Some more ideas while your working on the distributor. Make sure the shaft turns freely and has almost no play, bearings can wear out. See that the mechanical advance moves freely, the weights move freely, and the springs are not missing, broken or stretched. Check the advance can as well. The diaphragm can fail causing a vacuum leak, or failure to move.
