I used Rhoads hydraulic lifters which tell you to pump them full of oil before you install them so I'm not sure of this applies to other brands or not. Basically, I adjusted the pushrod down until it just began to plunge the lifter, then turned the adjusting screw 1/4" turn more then locked it down. So far I haven't had a problem doing it this way.
