DynaBro
I'm thinking I could cut the line and install this
www.advancedmistingsystems.com
And then run a short steel line to the vapor separator. Might work.
S.S 45 Elbow 3/8” Misting System Parts
SPECS: Type: Compression Construction Material: Stainless Steel Connects 3/8andquot; Nylon or Stainless Steel Tubing 1000 PSI Rated Assembly Instructions 1. Loosen the nut on the fitting. 2. Insert the tube into the fitting. Be sure the tube is bottome…
