Converting my 71 charger to a single-wire alternator. All new harness front to back. All connections triple-checked and all connections soldered. No shorts. Engine turns over, won't fire.
I have a sparker on the top of the coil, no spark when cranking. However, I get a spark when I turn the key back to 'run' and the engine coughs once, so IGN2 circuit appears to be doing what it is supposed to do. The brown wire from the steering wheel harness has solid connection to the plus side of coil.
To diagnose the IGN1 circuit, which I believe supplies current to the coil when the key is in the 'start' position, I run a wire from the battery positive to the plus side of the coil. Still no spark, which make zero sense. Still get the single spark and a cough when I turn the key back to run.
Busy ohming out the IGN1 wire from the steering console, but am wondering if there is something else going on I am not getting. Battery is fully charged, can't be the new alternator because of the single spark I get in the run position. I suspect I get the single spark because the alternator isn't turning and doesn't produce enough to keep it going.
What gives? What else should I be checking?
