Aeronet
Could you post some pictures?
I do. I will check and get back to you shortly.If I knew what the primary resistance is for the pickup, I could tell if its bad. Yet, I can't find any documentation on it. Anyone have one laying around they can test for me?
It could be the pickup coil.
Rotor installed?
Sounds like the only possibility
That .50 - .60 ohms is for the ballast resistor. -Ok did I read that right? .50-.60 ohms at 70-80 degrees? Mine is 248 ohms at 30 degrees here in Michigan. I thought it was 150 to 900 ohms?
If you check the resistance at the 4,5 pins of the ECU connection it should be 150 to 900 ohms. If you check the resistance at the terminals for the pickup it should be 400 to 600 ohms. That's how I see it.
I can post pictures of the whole section if you think it will help.
