66CoronetMan
I have a 1966 Dodge Coronet with a 440 I am having an issue getting 12 volts to the ballast resistor it is showing 9 and not anymore I have cleaned all the bulkhead connection. It was originally a points ignition had to swap to OEM style hei because the motor that came with the car was a 73 block and it is what I had but not getting the 12 volts I need for starting. I can run the motor by run a jumper to the positive of the ignition coil but would like to fix that. Any help would be great appreciated.
