STREETREBEL
1967 Belvedere, converted to electronic ignition.
It's been parked for 10 years, without running.
Just brought my 440 back to life and I have a problem with it.
The engine while in park, will rev up to around 3000rpm and then
it goes flat ( won't rev any higher ). It has fuel pressure.
I messured the volts at the battery ( 12.50 ).
Measured the volts at the wires for the ballist resistor ( 11.50 ).
Measured at the ballist resistor connected to the ballist ( 5.50 volts ).
Measured at the coil, positive/negative ( 3.2 volts )
Are these good numbers ?
