Some of you need more convincing. Others like to get their hands dirty, I get that, too. Me, I'm one of those "gadget guys". I like oil filter wrenches, too.
Its slight of hand. Look really close and you can see a can of spray butter behind the wd-40 can.
Here ten minutes on how to cut up t-shirts.
Helpful hint.
Some things absorb better than others.
Avoid synthetic fabrics. And your wife's stuff.
(Unless she says so.)
10 minutes to show how to cut up a t-stirt in hanky sized rags?
I change my oil er the car's oil when it's hot....and that means the car is at full temp. The oil comes out faster that way plus any impurities that the filter doesn't catch are suspended in the oil....right? Gloves? Heeelll yeah. That dang stuff is hot and don't wanna burn my purdy hands!Before an oil change, I have a 'beverage' then pull the drain plug. While the oil is draining, another beverage is had....then maybe another while waiting for the oil to drip off all the internals of the engine. By then, maybe another beverage or tow is had and while downin it, take a look at way ahhppenen on FBBOo. Be time fo anutter break en finis da chain tamarra.
No latex for oil changes.....just an old pair of well oiled leather ones.Not to mention that when you have latex gloves on, the drain plug is even slipperier than handling it with your bare hand. I've done a couple oil changes and used the tool. Works great!
With gloves, ya don't have to worry about moving fast....and when you get old, moving fast isn't always an option lolJust Move fast and you don't even need gloves lol
I keep a rag close just in case it gets me
But most of the time I don't need it.
Just something else for them to fu\\up. They can see the drain plugs in place how many will know if that valves closed.It would be useful for someone that worked at a quick lube shop that did oil changes all day.
