Tendy30: Realize that the Holley double pumper carbs are mechanical secondaries and are built to use with a manual transmission or an automatic with a higher than stock stall converter. A better choice for a street car, as has been said, is a Holley with vacuum secondaries or an Edelbrock 750 if you're going to hotrod the motor. The Edelbrock set-up is a comprehensive group of parts that will work well together; Or there are several good cams available from a variety of manufacturers and everyone you ask will have their own personal opinion usually based on their own experience. You can go on any of the manufacturers' sites and download or order catalogs that have a lot of information that will help you make decisions. All of the major manufacturers also have tech lines where they will make recommendations based on your set of circumstances. BUT FIRST, we need to find out why the vacuum is so low. Throwing parts at a motor that's sick is a waste of your time and money. Did that other member ever come by to check out your motor? BTW, Carter and Holley carburetors are/were made by 2 different companies. The numbers don't cross over. Jegs.com and Summitracing.com also have very comprehensive catalogs that show a huge variety of parts.
