Got my fingers crossed for ya!!
Thanks to Zack and 1967coronet440 for this posting. I, for one, appreciate you all spending the time to put this on here. Another winner for FBBO...
So it fixed itself? I was about to not even use my Elgin shafts and go a different route. Glad everything is good now.
post 69 ........ he grooved his shafts
Post 69 is mine.
Just changed out the break in oil (30wt) and put in 7qts. of VR1 20w-50. At temp and idle, 60psi, too much. So I’ll order VR1 10w-30. That should be just right with a WIX or Napa Gold filter.
Acually my drive train is quieter than the 30w break in oil, using the 10w30w. Penn Grade partial synthetic. I'm sure the synthetic helps with that.True. One thing I did notice, the valve train was quieter. But I’ll substitute some noise for more flow.
Standard, HV, or HP oil pump?Just bringing this back due to an update. After having a few other people look at my oiling on the rockers, the consensus was that there was not enough. So I bought some shafts from Hughes, they are banana grooved, swapped the rockers and wouldn’t ya know it, more oil coming out of the rockers. There is pools of oil around the bottom of the springs and more coming out the holes in the rockers along with more oil coming out in between the spacers/rockers. As a side note, hot idle oil pressure is now 25-28psi.
Put in VR1 10w-30 and it’s flowing a lot better than the 20w-50. Cold pressure is 80 and warmed up is 35. I’m happy with that.
