It really sucks when oncoming traffic has LED lights and blind the heck out of you, even worse is a four wheel drive that hasn’t readjusted it’s lights after a huge lift ...
Regarding adding relays without cutting into the harness.... I don't have all the terminals that I would need and am not sure what they even look like.
In one investigation, NHTSA found that a converted headlamp exceeded the maximum allowable candlepower by over 800 percent.
We are able to produce the LED Sealed Beams (which replace Halogen Sealed Beams) because the sealed beam unit in itself is a headlamp (contains a lens, reflector, and light source). When it is replaced, all these components are replaced with something new. When the integral beam was tested and passed to DOT/SAE requirements for beam the entire unit is passed, not just the light source.
Long story short, (I know its already to long) it is illegal to replace a filament bulb (light source only) with a nonfilament bulb in the United States.
It really sucks when oncoming traffic has LED lights and blind the heck out of you, even worse is a four wheel drive that hasn’t readjusted it’s lights.
about the wiring job for the headlight relays upgrade
diagram:
-untape dash harness at floor dimmer switch section. Maybe around 8-10" will be enough
-remove violet and red wires from floor dimmer switch. No need for cut, but just press the tab terminal and pull them out from swicth plug. Reset the tab terminal and reinsert those on a relay socket at terminal 87 ( output )
-Build a couple of wire links with two female packard terminals on each end. Packard 56 or 58, either one will work. If you use same colors than the harness once everything is installed the upgrade will be unnoticeable. Install these between 86 relay prongs and floor dimer switch. This will be the trigger ( input ).
-Feed relay 30 prongs from amm stud at black end.... For safety use a fuse... or better a breaker. This will reinstall the breaker function headlight switch got, but is being missed with the relay upgrade
-Ground as shown at 85
retape the harness.
this is how it looks on kick panel after the job
these sockets and terminals will make the job. They are "stackable". Along with the required wiring
SURE will need to upgrade the alternator path up to ammeter for safety and healthy connections at bulkhead.
and DONE. NO ONE WIRE CUT
RIDING LIKE THIS SINCE EVER WITHOUT A PROBLEM
So your still sending the headlight power through the bulkhead..... Sorry, I don't agree....
remember I'm a hard rock ammeter defender LOL... I have a bulkhead parallel wire path from alt up to ammeter
64/74 are those DOT compliant bulbs on the charger?
I'm in the automotive parts business, and our company checked into this. This is from Philips lighting on why they don't make LED headlight capsules and for those using other may want to reconsider.
The US Federal Motor Safety Standard (FMVSS) No. 108 specifically states for forward lighting (headlamps) that "You cannot replace your filament type light source (bulb) with anything else other than another light source"
The National Highway Traffic Safety Administration (NHTSA) has concluded that it is impossible to produce a conversion kit (converting a halogen system to LED) that would be compliant with the federal lighting standard, Federal Motor Vehicle Safety Standard (FMVSS) no. 108. These noncompliant kits frequently include LED modules, control boxes, relays, and wiring harness adaptors. The NHTSA believes this equipment presents a safety risk to the public since these kits can typically produce excessive glare to oncoming motorists. In one investigation, NHTSA found that a converted headlamp exceeded the maximum allowable candlepower by over 800 percent.
This is the same thing the OEM does to validate headlight assembly on a new vehicle, and why they can sell vehicles with LED headlamps.
Again, this is our suppliers reply, so if you want to use LED conversion headlight kits in you rigs, remember, this is at your own risk.
Mark
