Indy 452 Heads and MP cam
m300b
7:33 AM
Green Ohio
Stock build 383. Indy 452 reconditioned heads.
MP P4452783 cam.
Are the dual springs too much for this cam on break-in?
I bought the heads in 2004. Finally putting the motor together.
Post the cam specs.
Generally it's always advised to remove the inner spring on break in.
My question would be whether the dual springs are necessary on a street cruiser
Thought I was bad about 'life getting in the way' of doing stuff lol. I don't have the cam numbers handy....but even with a 509, with today's oils, it's best to break in with say a stock single spring imo.
Duration 268-284
Overlap --
Design lift @ valve.450/.464
Install centerline 113
Valve lash Int & Exh zero
Recommended spring P3690933 (also a dual spring)
