I've been out of the loop for a few days. I just received the replacement drier. FBBO member 1 Wild R/T informed me of something that wasn't shown in the instructions.
The drier is not supposed to be open to the elements for very long. The instructions show the installation to be simple: Attach this, install that, connect this, etc. I learned quickly that there was some additional work that was needed to make the stuff fit. The time it took to make a spacer bracket for the drier and to get the bolts from the hardware store probably resulted in contamination to the drier. I intend now to keep the original in place until all the lines are cut and crimped, then switch the original one for the replacement.
I'm still waiting for the taller brackets for the compressor. I got an email today stating that the brackets have been shipped. I ordered them August 29th, about a week and a 1/2 ago.
The routing of the lines is often done with function in mind without a whole lot of consideration for appearance. This kit has both the liquid and discharge lines on the drivers side with the liquid line going from the drivers fender apron ACROSS the engine and then into the firewall. 1 Wild R/T thought it looked cluttered and I agree. I prefer the line to be over on the RH apron and laying over the core support like shown below:
The pictures below are NOT my car! Red paint, yes but NOT mine.
The Road Runner above has both lines to and from the condenser on the right side. (As viewed from the drivers seat) This is either a modified Classic system or something else like Vintage Air.
I called Classic Auto Air and the man said that all their '68-70 B body kits use the same lines routed the same way. I am going to look into using a new hard line from the drier to and over the core support. then across the condenser to the fitting. The discharge line that connects to the compressor will stay on the drivers side.
