gtxrt
yes bigger plenum hurts a little torque down low and throttle response and picks up a little hp in the upper rpms. i tested 5 intakes on the street and you can find an old post of a member testing ch4b and I think a performer and weiand. it helped less than a tenth in a 1/4 mile I think it was .7 tenths where a rpm performer is good for about 3 tenths. if your going to run the ch4b, the performer and weiand don't expect much.A previous poster said the CH4B was the same as the stock intake, I respectfully disagree. The plenum is visibly larger and the cross section and volume of the runners is also larger. Are there better intakes? Absolutely, but for someone wanting to retain the factory Air Grabber it’s a good option…
