Here’s an item to check (Forgot I had this as a random shut off issue last year)
Check the 8 wire harness connection under the dash where the wires come out of the steering column (by your right knee)
Mine is a white connector. Pull apart inspect for any discoloring in the holes, loose wires etc, disconnect battery, spray clean with electrical contact cleaner, re-assemble.
I figured this out by wiggling it with car running and it shut off.
I cleaned and zip tied together tight.
Hope this helps
Hope this helps
