TorRed
- 3:41 PM
- Dec 12, 2023
- The Villages, Florida
I already have this cam for a 383/432 build. I'm now considering a 383/489 build for 1) a stock 'looking' build with 906 heads, exhaust manifolds and DP4B intake or 2) CNC'd Stealth heads, headers, and probably a six pack setup. I'd like some decent lope but nothing too radical. Will this cam work for one or both options?
20230712 Lunati Voodoo Retro Fit 3 Bolt Hydraulic Roller Camshaft BB Chrysler
Lunati's Voodoo Series deliver more area under the curve than any other series. This means more throttle response, quicker acceleration, more vacuum, and better efficiency. These factors, combined with max hp and torque, make Voodoo cams the best choice for a wide range of high-performance applications
This 1958+ Big Block Chrysler V8 361-440 is designed as a high performance street cam. Likes upgraded intake, carb, and exhaust. Needs 2800 RPM stall converter in most cases. Requires 9.5:1 compression for maximum performance
Vehicle Make | BB Chrysler, Chrysler |
Camshaft Type | Hydraulic Roller |
RPM Range | 2200 to 6200 |
Intake Lift | 0.535 |
Exhaust Lift | 0.550 |
Intake Duration at 50 | 231 |
Exhaust Duration at 50 | 239 |
Advertised Intake Duration | 282 |
Advertised Exhaust Duration | 290 |
Camshaft Series | Voodoo |
Valve Setting | Hydraulic |
Lobe Separation Angle | 110 |
