Steven Bowers
Well here I am attempting to drive my car for the first time in 4 months….I did drop tranny, z bar …ect. to clean and repaint…..went together great….put new GL 4 140 weight in tranny…..seemed as though it shifted smooth…..went to put it in reverse gear grinding…went to try shifting it in 1st, 2nd thru forth seem bound up….I can depress the clutch pedal seems smooth…..I can shift the gears with engine off seems okay…..what’s up…..I realize idle may be a little high…that’s why reverse probably is grinding….drive shaft can only go in one way….right…I’m open for some helpful hints…thanks to all who responded.
