Sorry to see & hear that,Hey guys... Had some bad luck this weekend. Went for my first pass in the car and right as I'm coming out of the burnout box the motor locks up. Took it apart the same night and this is what happened... I have no marks on any other pistons other than #3 and #7 where the seats actually came apart and out of the head... The passenger side head has 3 cylinders with material missing from the spark plug hole area... Any ideas on what may of happened? I had .100+ clearance from the piston to valve when I checked it. What a mess.
View attachment 560922 View attachment 560923 View attachment 560924 View attachment 560925 View attachment 560926 View attachment 560927
This one cylinder has the valve jammed partially open, Either bent or a guide issue? Will be interesting to hear what you hear back.Hey guys... Had some bad luck this weekend. Went for my first pass in the car and right as I'm coming out of the burnout box the motor locks up. Took it apart the same night and this is what happened... I have no marks on any other pistons other than #3 and #7 where the seats actually came apart and out of the head... The passenger side head has 3 cylinders with material missing from the spark plug hole area... Any ideas on what may of happened? I had .100+ clearance from the piston to valve when I checked it. What a mess.
Saw an engine once where the exhaust valve bent, then broke. When the engine shut off and they removed the headers, you could look up in the exhaust port, through the block, into the lifter valley and see the camshaft.I understand a valve binding up on too tight of a guide but how does that cause the seat to come out? not nit-picking or trying to cause any crap; just educate me or all of us.
thanks. my first thoughts were valve float in the water box, a lot of piston to valve contact and the seats beat out from valve bouncing on them. I sure hate to see this stuff; big dollars to fix.Saw an engine once where the exhaust valve bent, then broke. When the engine shut off and they removed the headers, you could look up in the exhaust port, through the block, into the lifter valley and see the camshaft.
If the valve bent in an aluminum head it could come down sideways and cut the valve seat right out of the head. I refer you to page 8 and the picture of the sideways valve head in the port.
I put my checker springs on cylinder 1 intake and exhaust, put some playdoh on the piston with some light oil so it doesn't stick and put the head on with the gasket. I just hand tighten it enough so its flat on there. Turn the engine over twice and take off the head and cut the prints out of the piston with a putty knife and measure with a dial caliper or micrometer. A bit hard to do with the playdoh, but as long as I don't make an imprint in the playdoh I can get a measurement. When I did this I was at .100+ for the intake and exhaust. Keep in mind guys, I do not have any marks from the valves on my pistons!Might be a dumb question, but how did you check piston to valve clearance? Tightest piston to valve isn't at max lift. Just ask'n. High RPM burnout could toss the lifter/rocker off the cam lobe & the valve into the piston. A possibility. Tight guide is a possibility.
sounds like your on it, and things will work out for the best.I put my checker springs on cylinder 1 intake and exhaust, put some playdoh on the piston with some light oil so it doesn't stick and put the head on with the gasket. I just hand tighten it enough so its flat on there. Turn the engine over twice and take off the head and cut the prints out of the piston with a putty knife and measure with a dial caliper or micrometer. A bit hard to do with the playdoh, but as long as I don't make an imprint in the playdoh I can get a measurement. When I did this I was at .100+ for the intake and exhaust. Keep in mind guys, I do not have any marks from the valves on my pistons!
Mike, I have a burnout chip set to 4000 rpm and a rev limiter to 6800. I was at about 5500 when I was coming out of the box. Springs were matched to the cam as well.
What I think happened here is I just broke a valve. That valve broke, and split the seat in a ton of pieces and set them all thoughout while the valve got smashed into the port. Those seat pieces went all thoughout the motor and raised hell on those other valves. I found multiple pieces stuck in other valve seats that kept the valves open, ultimately bending them... Maybe my prediction seems crazy, but from what I can see I think that is what happened.
Trick Flow is standing by their product and is working with me to get a solution on this issue. Honestly I am very happy so far that they are working with me on a solution instead of telling me to just hit the road... So more to come. You guys ain't hurting my feelings a bit with all this tough love, I'm only 24 and for someone to say that they know it all is just foolish! I'm here to learn as well so this kinda stuff doesn't happen again!
wondering this also; did he go full rotation when checking pis. to valve clearance.Might be a dumb question, but how did you check piston to valve clearance? Tightest piston to valve isn't at max lift. Just ask'n. High RPM burnout could toss the lifter/rocker off the cam lobe & the valve into the piston. A possibility. Tight guide is a possibility.
