TTSaleen
New vid -
1st real world driving experience to work and taking my daughter to school.
Ha. That is cool. My kid's principal stands at the end of the car pool line every day, you can see me wave to him in the vid once she gets in the car. I think he remembers me easily as I always show up in some kind of vehicle that stands out amongst the Prius/Mini-van crowd. LOL!Principal at our elementary school digs my black 68![]()
Quick check in.
Have any of you made your own AC lines? Do you have a recommendation on the lines, fittings, dryer, etc that I would need to buy to make this myself?
I can buy freon and have access to the professional gauges and a vacuum pump to get this thing filled, but I need a way to get started on making the lines and any other parts.
Ryan
Thanks. Question, what did you do for the pressure switch and wiring (if you added them)?As others have stated - I went to Classic Auto Air and got an assortment of lines/fittings but I also scored a hydraulic line crimping tool for like $40 so I just crimp my own --- slightly more work than taking it to a hydraulic shop but it's more than paid for itself
I have the hotwireauto wiring harness and the only wires I have are to the compressor itself. The harness has a blue trigger wire that when 12v is applied, it turns the compressor on.
I have considered buying the crimper kit so I can make my own lines, I am just unsure on the fittings and adapters needed to convert from the factory firewall connections to my newer items (2006 charger condenser and compressor and I need to pickup a new style drier).
Ryan
Thanks! Got a link to that -6 male fitting with the attached nut?The pressure switch should just be wired between the triggering relay and the compressor - this essentially deactivates the A/C system if there is a pressure issue.
The factory firewall fittings are IIRC a 10 and a 6 or something like that. The -10 should use a normal o-ring fitting that is commonly available. The -6 is a male with an attached nut means you'll need a threaded fitting to receive it like this one
As for the compressor, Bouchillon Performance sells adapter blocks that bolt to your compressor and allow the use of the commonly available A/C fittings.
Available Here
If you plan on going to a full R-134a conversion remember to rebuild your factory A/C box and replace all the O-rings with R0134a compliant ones.
Ryan
I used the compressor that came with my 2006 6.1 on my 68 Charger. I rebuilt the heater box and had the evaporator tested. I bought a new condenser, drier and expansion valve (stock for 68 with R12) I had a shop fab the plumbing under the hood. Since you have electric fans you will need to buy a Trinary pressure switch for the drier because you need the extra contract to turn the fans on when the AC is activated. Charged it with 134 back in 2015 and it has worked perfectly since then.Thanks. Question, what did you do for the pressure switch and wiring (if you added them)?
Ryan
Great info, thanks!I used the compressor that came with my 2006 6.1 on my 68 Charger. I rebuilt the heater box and had the evaporator tested. I bought a new condenser, drier and expansion valve (stock for 68 with R12) I had a shop fab the plumbing under the hood. Since you have electric fans you will need to buy a Trinary pressure switch for the drier because you need the extra contract to turn the fans on when the AC is activated. Charged it with 134 back in 2015 and it has worked perfectly since then.
I suspect that Dakota Digital apparatus you put in to run your fans is what keeps your engine running after a shutdown. Probably needs a diode in the circuit. I would call them to see how to handle it. As for your starter issue, I would find some way to wrap it or the header since it is so close on that side. It sounds like you need some sort of heat barrier to keep the starter temp down.Few days of driving around and I have a few small bugs to work out.
NOTE - I also swapped the American Racing wheels back onto the car that came on it when I purchased it in Dec 2020.
1. If I have the AC on/running which has the inside fan blowing and turn the ignition off, the car will continue to run. It is as if the inside fan is acting as a small generator and keeping the ignition alive. It will eventually slow and turn off, or I can simply push the off button on the AC and it will shut off. What have you guys done in this situation to isolate the voltage so that it only flows to the fan but not back towards the source?
2. It appears to be heat soaking the starter in this summer heat (90 plus degrees this week) and my long tube headers. It is slow to turn over after I park it and try to restart within a few minutes, but if I let it sit for say 30 minutes it turns over fine. I already have large cables, good grounds, and a fresh battery. So I will probably heat wrap the battery cables and the starter to keep as much heat away as I can.
I took the car over to the original owner's house today to show it to him.
Sadly he was quarantined due to his grandchild giving him Covid so he could not come outside to see the car or talk to me in person. So I texted him and sent him a picture from his driveway and told him I would come back at another time to show him the car and let him drive it again!
