furyus
- 3:59 PM
- Jan 5, 2010
- weeki wachee, florida
I kept getting that GM power steering hiss, when turned fully left, or right. His pump puts out more pressure. It is a little noisy. You can hear a slight pump sound through the steering column. I wondered if I should try the stock pump with the larger hose, and fitting, I just haven't done it. Also, some type of isolating joint in the column would be a help. Mopar style coupler is metal to metal.Why did you end up using his pump?
