Mopar-Charger
Primary bowl is filling up past the float. I've swapped the needle/seat as well as the float. WHy is this happened? Fuel pressure is just under 6 psi.
THis is only happening on the the primary side, the secondaries are fine.
I'm stumped, no matter how much I adjust the float level, it fills the bowl full, flooding the carb.
(While I had the float off, Held the float up to "close the needle and seat" when I did that, I blew into the inlet for the gas and I couldn't. I have no idea what this is and I can't figure it out!)
