JetCoronet
I am having alot of trouble finding information about stock kickdown linkage on a stock 318 LA with a Carter BBD hooked to a torqueflight 904. Its in a 1969 Coronet 440. Does this look right? Other than the missing clip.
Looks good at this angle. Yes, a washer and clip to keep the slotted lever in place.I am having alot of trouble finding information about stock kickdown linkage on a stock 318 LA with a Carter BBD hooked to a torqueflight 904. Its in a 1969 Coronet 440. Does this look right? Other than the missing clip.
Thats a lot older style and does not look correct.
1-At the carb stud you need a washer and clip. 2- the spring as I recall should go into the hole in the rod. There also should be a washer between the spring and the bracketI am having alot of trouble finding information about stock kickdown linkage on a stock 318 LA with a Carter BBD hooked to a torqueflight 904. Its in a 1969 Coronet 440. Does this look right? Other than the missing clip.
From the 69 FSM.I am having alot of trouble finding information about stock kickdown linkage on a stock 318 LA with a Carter BBD hooked to a torqueflight 904. Its in a 1969 Coronet 440. Does this look right? Other than the missing clip.
Ive found alot of pictures but i havent seen specifically this one. I think ive got it right.
That picture is from the 69 FSM. Your set up is close just needs a couple small fixes to be correct.Ive found alot of pictures but i havent seen specifically this one. I think ive got it right.
