fmahannah
1963 Dodge Polara Max Wedge Tribute
- 3:17 AM
- Sep 25, 2014
- Dahlonega, North Georgia
As a last resort to try to free stuck oil rings before pulling my motor, I tested filling each cylinder (with heads off) with various recommended chemicals and home brews just to see if any seemed to lift out deposits when pistons were rocked back and forth.
Had best results with MMO then Kroil, with the kroil actually working best.
When I tested with Kroil though I noticed something that scared me a little. Leaving a cylinder full overnight, the next day I sucked the kroil out and saw what at first appeared to be rust in the lower half of the cylinder bore where the kroil had sat. It was a lighter brown color and not carbon. When I rubbed my finger on it it felt slightly rough and I was worried that cylinder wall was etched or rusted. However rubbing with finger loosened it and scrubbing with a little more kroil removed it. I am not sure if this was just gunk that had been lifted from rings and settled around the lower wall, or if perhaps the kroil actually lifted and removed some sort of coating that was on the cylinder walls?
Is there a coating that can be on top of the honing marks or down in them that might be dissolved by the kroil and lifted to the surface? Is this what people normally deglaze with a ball home before changing rings?
If this is a deposit or glazing on the cylinder walls then since I can't be sure kroil removed it all I will probably pull the motor anyways so I can properly bust the glaze and replace the rings, but I figured while I had the top end off I would see if anything could actually free up the oil rings.
