So an update on my cooling situation. A Hayden tranny cooler was installed in front of the rad, along with new tranny cooler lines throughout. The original clutch fan, a 7 blade, 20" diameter unit was removed, and replaced with a 6 blade, 17" diameter flex fan, which allows a shroud to be used. I also swapped in a 160 degree stat from the old 180. As well, and don't ask me why I didn't do this before, I installed a mechanical Auto Meter water temp gauge, while keeping the original gauge in the dash working so I can finally see the actual temps and how hot I was running according to the old gauge. A few hours ago after idling up to temp, allowing the stat to open, I topped up the rad, and went for a drive. Now it's only 78F here today, after a few days of 90-95F. While driving at 30-40mph, the temps stayed around 165. Any longer stops, like 5 minutes at idle, temps up to 180-190. 15 minutes at idle, after a 30 minutes drive, and 215. At 215, I shut it off. I'm running premix Prestone. I have some concerns and need advice, as usual, lol.
What temp would be considered maximum? As in if you hit that temp you would shut the motor off and let it cool down. Is it possible that the 20" 7 blade clutch fan was cooling better without a shroud than the 17" 6 blade fixed fan is with a shroud? I guess I can test the theory. What about Water Wetter? If the high temps don't change with either fan, any thoughts what to try next? These scorching summer temps have me keeping my car in the garage instead of enjoying it until I can figure this out.
