Larger core support or trim existing
rjbsj
New Member
1:47 PM
NC
I have a 69 Coronet 440 that came with the 318 engine. In the process of stripping the car down to make a super Bee clone. Obviously it had the original radiator and core support for the smaller radiator. I will be putting a 440 motor in the car and I’m sure it will need a larger radiator. The opening in the core Support looks mighty small for what I would assume needs to have a larger opening for a larger radiator. Am I looking at this wrong? Can I simply trim out the existing core support for a larger radiator opening or does AMD or someone make larger opening core supports? Thanks
I have a 69 Cornet 440 that came with the 318 engine. In the process of stripping the car down to make a super Bee clone. Obviously it had the original radiator and core support for the smaller radiator. I will be putting a 440 motor in the car and I’m sure it will need a larger radiator. The opening in the core Support looks mighty small for what I would assume needs to have a larger opening for a larger radiator. Am I looking at this wrong? Can I simply trim out the existing core support for a larger radiator opening or does AMD or someone make larger opening core supports? Thanks
Just put a different Radiator Yoke on the RH side...
Dodge Charger / B-Body Radiator Support Bracket 26" 68,69,70 1968,1969,1970 for sale online | eBay
all years/models is certainly not my field of expertise, I guess my point was Mopar built 440 auto cars such as my GTX with 22 in radiators; therefore running a 26 probably isnt necessary, unless maybe with a big increase in horse power
I put the panel in for the 26 in. Radiator in my Rr
