BanginGears
I lash cold and check mine every 12 passes.
I've checked twice hot to see how much they loosen up.
doug how much tighter do you set yours from what the cam card says? when setting them cold with a iron block and aluminum heads.
.005-.006"doug how much tighter do you set yours from what the cam card says? when setting them cold with a iron block and aluminum heads.
The base circle shouldn't have any dips.... Which what you describe sounds like a dip... In theory the valve needs the lash to assure the valve closes fully so heat can transfer from the valve to the seat.... But then again racers tweak the lash to slightly alter duration so you have room to play with and I don't think .002 is critical... The EOIC is just that, at the point of the exhaust lash being taken away & the valve moving but before it crests the lobe you set the intake... And as the Intake is closing but before it hits the base circle you adjust the exhaust...
Again, .002 won't make or break ya..
