I'm also interested in this, I have stock/worn out everything small block/auto with intentions of 440/727 swap pro touring style build. Trying to buy one time, would like it to be balanced front to rear, using T-bars and leafs.
So far here is my take away on all of this, while there are many choices on the market it would seem that there really isn't any reason to spend $700+ on a set of springs when you can either use what you or purchase something like the Mopar springs or ESPO (which have a good rep). After thinking about it I do not think I would get a lowered spring (say -1"), rather I would use a 1" lowering block. My reasoning is that by going to the -1 springs you (I) am limiting my options in that I cannot raise the car easily with those springs without using longer shackles and adjustable front hanger both of which would not be beneficial to handling really (IMO) whereas if I were to go with stock and use a block, if they ever sagged I can just remove the blocks.
I also believe that for handling you need 3 more things; good - great shocks (this is where the real expenditure needs to happen), large sway bar, and good tires. So I have decided that at least for me I am going to use the following;
Stock springs (at least for mock up, if they are bad I will get new Mopar or ESPO springs)
Hotchkiss or maybe a Firm Feel HD sway bar (HK is 1" Firm Feel is 7/8)
Wheels and tires remain an unknown but I would like to go no more than 17" and use a steel wheel with the stock Dodge hubcaps (I like the look and there is a company that makes these wheels). I am thinking 17" because I am going to be running large disc brakes and a hydroboost system (bought some 2018 Shelby Mustang GT500 calipers).
In the front I will be running at least 1.14" T bars (Firm Feel), large sway bar (probably Hotchkiss), reinforced LCAs, Firm Feel tubular UCA (they offer more adjustment in the design over stock), fast ratio pitman/idler arms, Borgeson PS box, poly bushings, adjustable struts and a reinforced K frame.
I am also going to have full vehicle bracing; USCT sub frame connectors, torque boxes (I will make), under fender braces (I will make), radiator core support brace (I will make) plus I am considering developing an upper shock tower brace (still thinking about this).
My hope is that this set up will yield a car that handles well yet rides ok (less concerned with the ride but doing want it to be an issue).
