Borgeson box AND fast ratio arms?? Have you driven that setup before? The Borgeson is already faster ratio. Adding fast ratio arms on top of that might make for some twitchy steering in the turns. I used to run fast ratio arms with my Firm Feel stage 2 box. It handled pretty well, but the fast ratio arms increase the steering effort considerably (about 5x as much). Not quite as much as manual steering, but almost. After a few road race events and then really getting to know the feel of my car on the street, it often felt twitchy on a full circle off ramp, so I went back to stock idler and pitman. Not as precise now, but with lots of caster and a bit of camber along with the ability to spin the wheel quicker, it's much more pleasant. Next up for me is a Borgeson box swap with stock arms.
I also run the Hotchkis rear leafs along with their hollow front sway bar and a Firm Feel frame hung rear bar.
I like the Hotchkis leafs. They say they are 1-inch lower than stock, they're already front clamped, and as you said they have a stack of shorter leafs. I'm no expert, but when selecting your leafs, also pay attention to the advertised spring rate. I believe the Hotchkis are 160-lb/in which is higher than stock. It's fine for the street and track, but you'll need to balance your front torsion bar spring rate. I'm running 1.00" T-bars from Firm Feel.
By the way, a bit of searching and I found the Hotchkis leafs on sale for $630.
Hotchkis Mopar B-Body 1 inch drop Geometry Corrected Sport Leaf Springs
Summit's also got the Hotchkis for $687. Don't order direct from Hotchkis, it will cost more. They don't want to undercut their distributors.
