ckessel
Which is the reason I surf on my Laptop only, other than big screen is easier to see. Can't fat finger.
@toolmanmike . I looked in my reactions score. Looks like I accidently gave 14 red x's over the years. Is there a easy way to to find them, to remove them?You must be using a cell phone. There is no good place to put them that won't be in the way. There's a lot going on in a small screen. If you are right handed you might catch them as you scroll. You can go back and edit them or delete them which you should do. .
I would have to poke around. I don't think so but I will look.@toolmanmike . I looked in my reactions score. Looks like I accidently gave 14 red x's over the years. Is there a easy way to to find them, to remove them?
@Joeychgo , I see "reactions received" but not reactions given. Is there a place where members can view their own?@toolmanmike . I looked in my reactions score. Looks like I accidently gave 14 red x's over the years. Is there a easy way to to find them, to remove them?
Scroll back thru the thread. You your self can see where you gave red x's and hit "remove".No, I am on a desktop however at times miss the mark. I'm not sure what you mean by going back to edit or delete and as with Joeychgo only see reactions received and not sent.
I guess I should start slowing down on the mouse movement as I seem to be hitting the disagree button a little too often. If I read a post that I do not agree with I just move on without tapping the red button as everyone is entitled to their input/opinion on this site. Being new to this site I do not intentionally hit disagree as I am here to gain knowledge and don't want to Pi*s anyone off.I got it twice. I must be special.![]()
Thank you for the tip. Much appreciated.Scroll back thru the thread. You your self can see where you gave red x's and hit "remove".
Just texted my Cousin after reading from another B Body member that stock Dodge hangers are about 3 1/4 inches long to center of bolt hole and you have to use a hanger that is 2 inches longer when using the shorter Super Stock springs. He will get back to me with measurements.No problem, there is a little red x on the bottom, you must have pressed it accidently. When you do it means you disagree. Super stock springs are shorter. So you need a longer front hanger. I don't know why only one side. Are both front hangers the same size
Thank you very much for the information, it will be helpful.
