So I'm getting a lean misfire through the carb. I thought maybe it was weather related but its not, its happened once in hot weather and once in cold weather (yesterday). The car's a '69 Bee 440 Six Pack, 4:10 gear.
So here's what happens. If I drive the car for a steady length of time at 55-60 cruising mph with the cruising RPMs at roughly 3,500 and then come to a stoplight. From the stop I try and launch the car and that's when it lean misfires through the carb (nice cloud of smoke came out the hood scoop yesterday). Prior to the extended drive, the car launched fantastic and hard from a dead stop. The car doesn't have a vapor separator down by the fuel pump so might the fuel be extra warm as it enters the intake and then detonates because the car was driven hard for that length of time? Total timing if I remember is 37 degrees, perhaps I need to dial it back a degree or two, or get a vapor separator installed, or adjust the accelerator pump cam.
Thoughts on this please....
