maddart
All was working just fine. I just replaced a cheapy tach with an autometer which i wired in with a 4 pin connector. The original tach was also wired in this way. Plug and play right?
Now the left turn signal is only working in the rear. The fender/running light and dash light are out for the turn signal.
The only difference is that i snugged up (4" hose clamp) the tach further forward toward the directional arm approx 2 inches away from the arm.
Nothing seemed to compress or colapse so i don't know if this is an issue.
1967 coronet 383 4spd.
Problem solved-Connector from stering column was partially unseated on one side only. Squeezed connector and reseated. Everything works fine.
