He stated why he installed it in the first original post. He kept wiping camshaft lobes with the Comp Cams which is common on that series as it is posted all over the internet.
I would seriously look into a Mopar Performance .590 solid lifter camshaft if you are looking for something reliable, with street friendly valve spring pressure, and performance (if you want to stick with a Mopar Performance Cam). This camshaft would also bleed off most of your compression. I get 14-15MPG on the highway with a 833-4 speed, 4.10 rear, and 30" tire now. With a factory 440 other than a comp .480 camshaft with 8.5:1 compression, along with 3.91 gears and a 26" tire, the car got 17mpg on the highway...
Your best bet obviously would be a custom ground camshaft... Just don't expect earth shattering performance if you stick with a hydraulic bumpstick.
I also run timing at a locked 34* on pump gas, as instructed by one of the top tuners in the state of Florida. I don't believe that engines with Aluminum Heads need as much total timing as engines with Cast Iron heads. So, more timing, does not equal more power. The Mopar Performance Engine Manual actually states to run TWO points of additional compression when switching from cast iron to aluminum to restore power loss, but the basic is just to add one point. What you are saying is that if your engine was running 9.8:1 compression with cast iron heads, it wouldn't run on pump gas? Get a compression gauge and check your cranking compression. If it is in the 200+ psi range, you are obviously over the hill' on pump gas. 180psi is about as high as you want to go. As stated before, a larger camshaft with much more duration and a tighter LSA would cure this problem by bleeding off cylinder pressure.
