Every get a chance to check your cranking PSI?
Ha ha... Not yet. Maybe I'll take a look tomorrow.
EVERY time I read someone suggest this I get a D'OH ! (Homer Simpson) type of feeling. I
know that the cranking compression number is a critical aspect of the issue and I keep forgetting to check it.
In Feb 2012 I pulled the motor to hone the cylinders and put in new rings. Before the teardown , the lowest hole read 178 and the highest was 192. I'm sure that with a better ring seal, I must be over 190 in all holes now.
I REALLY wish I had better advice on compression when I first built the engine. I
could have replaced the pistons last year when the engine was out, but like a
cheap***, I just had the old pistons bead blasted and reused them.
I know that many here have said that this compression ratio can work if I have quench and the right camshaft, but a reverse dome piston with an even 10.0 to one would have allowed me some wiggle room.
Regarding solid lefter camshafts: WHO the heck do you trust? I've had a
W I D E range of quality on advice. The guy I talked to at Comp Cams thought my '509 cam was adequate and even suggested using a THICKER head gasket to drop compression. I posted that here and faced a barrage of responses telling me that the thicker gaskets would
eliminate any "Quench" I may have and actually
increase detonation. I googled
Quench and spent a couple hours reading about it on several engine forums.
I am fully aware that there isn't any
one perfect camshaft for any engine, only a few that work well and a bunch that will not. I'd be happy to try a solid lifter cam if I knew who to trust. I am not married to the Mopar Performance brand, but I have heard the .528 is popular. Subtract the lash and I am no bigger than I am now though, right?
I recall reading some responses suggesting a minimum duration of 240-250 @ .050. I am already there with this 292/509 cam.
