- 12:25 AM
- Dec 4, 2009
- Pasadena, Texas
round nose....both are jacketed rounds. What should I look at?
Brass....don't know the weight. Seems like the magizine isn't as tight as my other semi autos that I have and those are Glocks. Even the round nose seem a bit rough going in. The hollow points were .003"-.004" larger and I filed one round nose tip to about 1/16" flat and that one wouldn't chamber either.Magizine lips, feed ramp , and the load components of each round.
Bullet weight, fps, brass or aluminum.
This one is from a friend that passed away recently and I'm trying to help his widow liquidate some stuff. Thought I'd get the Llama but after telling her I'm interested, I'm not so much now lol. Did buy a Mossberg 500 12g and it seems to work ok but haven't fired it yet.Look at a modern pistol. Taurus G2Cis a good one
Well, if I'm going to go after a different semi-auto pistol, it won't be a 9. Thought this one might be ok for the price but looks like I thought wrong. Thanks on the comment on the Mossberg. It's my first pump and kinda like itThe Mossberg is timeless. But if you need hollow points in a pistol you are a lot better off with a newer generation gun.
You could sell the Llama and probably get a g2c and a case of ammo
We are spoiled with the excellent semi autos we have now.See if Wilson Combat makes 'a Mag' for it
well worth the $30 or so $$'s (don't buy the cheap mags)
Midway USA or Bass Pro maybe even
I'm not familiar with Llamas
But;
I wonder if the spring 'in the org. Mag' may be weak too
or stuff is dirty
(or slide hanging up/dirty or recoil spring could be weak/junk)
they need to be cleaned too,
especially if it's left sitting loaded or cocked & locked for a long time,
which could weaken the spring 'allegedly'
or when shot & not cleaned well,
even the mags need to be cleaned every so often too
Maybe take it to a good Gunsmith
maybe the entry ramp or maybe even on the forcing cone/barrel entrance
may need to be touched up, and cleaned up
(I'd still suspect the Mag 1st or a spring)
&/or
if the ammo stuff 'is reloads', check the OD diameters of the rounds
some rush the process & don't size them well/right
it's not uncommon for older semi-autos 'to not like'
to cycle/load semi-wadcutter/wadcutters
(flat tip bullets mostly for target practice)
or
lighter loads not enough 'oomph' to cycle properly
or hollowpoints,
they like full loads/'hardball style' jacketed rounds
