Do any off you guy's run a locked out distributor on the street, and if so, what stall convertor are you running, if automtic off course. I might try it on my engine since it likes a lot of initial timing.
Have you considered hooking it up to manifold vacuum, to give you max vacuum advance after the engine starts?
How about keeping your centrifugal advance, blocking your vacuum advance. Set your max advance to the 36 you want. Put a lighter spring on the centrifugal so that your all in just off idle.
Hey how do you lock out the timing? I am running a MSD Pro Billet with the 6AL. I am detonating so I put a 14 degree bushing in and slowed my advance as much as I can with the heavy springs. No longer detonating but idle at start is difficult to maintain cold even with the manual choke I added. Low rpm idle is not great in gear.
Yup I got the 14 degree bushing in there now!Its in the MSD manual, https://www.jegs.com/InstallationInstructions/100/121/121-85551.pdf
FBO sells 14° and 10° bushings, they work great.
you need alot of initial timing with these cams.
Thanks Rob, yes I got my 14 degree bushing from you but I might now need the 10 degree. Oh and that bushing was dead nuts 14 degrees too!I sell the 10 and 14 degree MSD bushings for a $10 each.
Been making them for years. Started on a hillbilly lathe... drill, mandrel and a file held by a vise. Now they are run on a CNC.
JMO, if the car runs better at idle with more initial timing and the starter will handle it, dial it in. Auto cars can be very sensitive to initial timing, especially larger cammed engines as noted. Really tight converters don't help!
Rob
