I'm just jumping in here after watching the vid and reading all the comments. Here's my $0.02.
It's trying to crank at the end of the first cycle in the vid AND you can hear it doesn't appear to be getting spark during cranking... that's why (I think) it sounds like the timing is retarded.
In short, you very likely have an ignition issue. As you know, there are effectively 2 circuits (one for each key position, on and start), one for cranking and one for running and runs through the ballast resister. You may have a wiring issue or a controller issue.
Also, your choke blade is SUPER tight. On a 6pack the center carb is the only one being used at low throttle... meaning the other two carbs are also shut leaving only the center one to permit air into the intake. In short, you're very likely flooding it, starving it of air, and on top of that potentially not getting spark during cranking.
My recommendation for steps to take...
First, back off the choke - a lot. If you have to... make half closed, max. Keep in mind you're trying to start a v8 with a tiny 2 bbl carb... so once the choke is opened for starting, don't hesitate to give it a few presses on the accelerator peddle. Honestly, I wouldn't even bother with the choke... just - for now - lock it fully open so the engine is getting air.
If that fails, then put a test light or meter on the cracking circuit of the ignition and test the voltage. You might find you see nothing. If you're seeing no voltage and you're running a stock ignition system, then there is an option, which is: bypass the resistor and connect the cranking and ignition-on wires together... that will ensure voltage throughout the process. Byproduct? It will/can cause other issues if not repaired correctly. It's a Band-Aid just to confirm the issue.
HTH
