Bryan Refino
So I have a 1969 Plymouth sport satellite I've been trying to upgrade since I recently bought it , the last owner " fixed the wiring " I replaced the broken circuit board , bad amp , fuel and temp gauges . I also installed the ivr-4 limiter , the temp sensor is new and so is the fuel tank and sending unit , my fuel and temp gauges constantly pulse from empty to almost maxed out , and I also noticed the two wires on the back of the cluster ( one red one black ) are both "hot " is the black supposed to be a ground ? could a faulty ignition switch be causing the black to be hot ?
