Jonnyuma
- 7:00 PM
- Nov 15, 2010
I recently had an intake gasket failure that put water into my oil. Following some suggestions I got here one FBBO I doused the heads and lifter valley with clean diesel fuel until it ran clear-ish out of the oil pan drain, buttoned it up, added oil and a filter, and ran it for about 10 min. Drained it, fresh oil/filter and now my oil pressure is scary low. 50 psi on a cold start, but once it warms up its LOW. At 2000 rpm its at around 15-18, at idle in D it drops to 0 or so close to it that it doesn't matter. This thing pretty much lives at 1900-2000 rpm, which is my 20 mile each-way-to-work drive on a 45 mph two-lane (2000 rpm puts me at about 51 mph). The readings are off of a mechanical gauge. I'm not getting any strange noises (yet), but I'm wondering what may be causing this. I did use a cheap filter (Purolator) for the oil change, figuring on changing it out again after a week for my usual NAPA filter. If I'd known a filter could cause this I woulda just used the better one to start with. CAN a crapcan filter cause this?
This is on a stock 360 daily driven vehicle. No real racey stuff unless you count an Airgap intake and 4-bbl as racey. My buddy says "bring it over, we'll pull the motor and change the oil pump, water pump, timing chain, etc. Great, but his garage is 200 mi away, and I don't think I oughtta drive this car 200 mi with sub 20 psi oil pressure. 10w-40 in it now...heavier oil? Better filter? Shoot, I gotta git to work.
