moper
You should have a ton of piston to valve space - even though there are no valve reliefs the piston is waaaaay down in the hole. The cams you should be running won't get anywhere near them.
Stegs, I have a low Comp '78/400 & thought about the 75cc head and a mild cam.
The only issue I have about it all is, how much duration & lift can the stock engine take with these heads?
