Lower control arm stiffening plates?
Amazing how a thread can turn into a shitshow for such a meh topic :) I'm actually surprised no one mentioned not running urethane LCA bushings..
The OP's opening question and related title:
"I was thinking adding the lower control arm stiffing plates. Thoughts?"
Thanks for opening that door. :poke: :poke: :rofl::rofl:It won't be long now.
I put urethane bushings in my rotary radio knobs. Holds the station better, but it squeaks when I change stations.
Cheap and easy to do. There are no downsides to using the plates.
Bingo! As car enthusiasts, we often make mods without any “engineering analysis” , especially when the mod seems logical, and “analysis” takes 20x the effort of making the mod!
I agree, and GIGO is still valid. :BangHead:
Effort is a lot of work.
I will most likely do the stiffening plates when I do the lower control arm bushings and the strut rod bushings. I did the upper bushings and all the ball joints and tie rods in 2023.
Hi everyone I personally gone down the rabbit hole. Larger tie rods, welded braces on lca, larger front sway bars, kyb shocks etc, etc. Borgeson steering box , everything new or rebuilt. Front and back. I did it bc I want a nice cruiser. That can handle turns and roads. I believe there's no right or wrong. Just personal preference & Safety.
Well, the KYB shocks are a terrible choice for a cruiser. They make the cars ride like a Conestoga wagon.
Wow!! Thanks for info. Have not installed them yet. Only have for front. Out back coil overs, newer stock springs & rear swaybar. I think now I have Monroe or Gabriel out front.
