BeepBeepRR
I have a few wires that I can't find in the schematic. There is a shorter blue female connector in the alternator area. Then there is a longer blue wire in the same harness that has an angled female connector. And off the same harness by the firewall connector there are 2 wires I cant figure out. One is black with a green tracer and the other is black with a white tracer. Both have single round female connectors.
My guess is the Blue longer wire is for the AC compressor. I found a semi half assed schematic showing the blue wire with the angle spade going to the pressure switch for the ac compressor.
The shorter Blue round female? Mystery solved on this one. 1) solid dark blue wire
A) carburetor solenoid, can be used if your running an electric choke
B) on carburetor
The black with the white tracer and the black with green tracer? Still cannot find these in any schematic.
B) on carburetor
