I've made more than 65 posts in one night.
I had this same brake issue in 2012.
I wanted to switch from power brakes to manual for the sake of simplicity. I had 12" front discs and 10.7" rear discs. I tried a 1 1/8" bore, a 1 1/32" and 2 that were 15/16" and all of them gave a firm pedal with terrible braking.....it was as if whatever the pedal was sending was not getting to the wheels. I could barely skid on gravel. I put the power booster back on and later noticed that I had a disc/drum proportioning valve in....with the 4 wheel disc setup! The Prop valve reduces rear pressure in disc/drum systems to avoid lockup and was rendering the rear brakes almost ineffective. The power booster was masking the problem.
Here we are, years later and I'm in the process of upgrading to bigger rotors and adding a hydroboost unit.
Good luck to you.
