Ur right, had brain freeze for a moment there!You think they will run on that. Figure use to be around 24.
Well Cranky, the big diesels run 4 usually. Takes a lot of amps in the cold and cables as big/bigger than your thump(2/o,1/o). Personally I wouldn't go deep cycle, wrong application like said above. PLUS, diesels have 12.5/13+ compression.
That sounds like one of them is getting weak and draining the other. (Dead or dying cell?) That symptom description is exactly what happens to mine when one goes away. If you had a single battery, you might need a jump. When one of my redtops went sour, i just replaced both with interstates, kept both redtops for a bit, checked with a vom, one showed 12.5v, one showed 10, the next day, 9v.Well, going with one for now and see how it goes. It's been starting ok with the old batteries but the starter has been a bit slow even after charging them but once it's running, the alternator charges them up even more and the starter turns normally even after sitting for a day. It's when it sits for several days that things get slower....
Well, somehow I ended up with a battery that was 3 years newer than the other.....7 and 10.That sounds like one of them is getting weak and draining the other. (Dead or dying cell?) That symptom description is exactly what happens to mine when one goes away. If you had a single battery, you might need a jump. When one of my redtops went sour, i just replaced both with interstates, kept both redtops for a bit, checked with a vom, one showed 12.5v, one showed 10, the next day, 9v.
The good redtop still holds a charge at eleven years old.
