Update!
I think I might have finally found the problem...
I was so focused on it being an intake leak that I did not really pay attention when I had the heads off the last time.
I pulled the passenger side exhaust manifold off in preparation for sending the heads out to a shop to be rebuilt,
and this time there happened to be enough light in the engine compartment to look down the exhaust pipe. I saw
a trail of oil from the top down. Looked at rear exaust port on that side and it had oil coming out of it, the entire valve
and port was coated with oil.
Apparently the exhaust valve guides are shot? Inside these valve covers the oil gets pretty deep at the rear before
it reaches the drainback areas which are up high to the carb side, so the rear valve quide is exposed to oil all the time. With umbrella seals that
move up and down with the valve and since the oil was entering below them, oil can just pass right down the guides?
Getting all new guides and positive seals for both exhaust and intake valves when the heads are worked on, but it will take
three weeks. I will let you guys know how it turns out.
