QQBlue1
I need to replace the engine wiring harness on my 68 Charger with a small block. The harness looks fairly original with some mods over the years such as the MSD distributor I added and auxiliary temp, oil and alternator gauges. Also, still have the ballast resistor wired in, a voltage regulator and the alternator with one field, the round type not a square back. It's a pretty simply set up. Everything under the dash is a stock replacement harness I installed about 12 years ago.
I have the wiring harness for a big block w/ an electronic ignition sitting on my shelf. Would I run into problems modifying that harness or would I be better off buying the correct harness? Thanks!
